![]() | Home > Technical (L322) > Braking over 50mph- steering shudder. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I take it you have had wheels balanced?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The rears when seized heat up the rear wheel on the offending side too, so can easily be checked by one wheel being hot |
Phi. Member Since: 11 May 2015 Location: Halifax Posts: 14 ![]() ![]() ![]() |
Thanks chaps for the prompt reply- the rears seem fine with no noticeable difference in the temperature. |
In that case change front wheels to rear and try again? Worst case, can you get/borrow another set of wheels to try?
The discs are Eicher and the pads Pagid! On inspection they seemed to be ok with no uneven wear or scoring. |
I had the front disc checked with a dial gauge, this showed that the discs were out of true.I have had them replaced and now the brake shudder has been sorted.
