![]() | Home > Technical (L322) > Side Step and Front Mudguard Fitment, MY02? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6423 ![]() ![]() |
I have looked at the accessory fitting guide for OEM side steps and front mudguards but it doesn't help.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Mine were slotted together. The mudflaps aren't attached to the sidesteps. There is a plate which is screwed behind the lower body panel. The panel has to be removed to access the bodywork behind. The side panel is replaced and drilled through to allow the screws to pull the mudflaps into the bodywork.
Many thanks, sounds like there are options! Pretty certain mine were factory fit so will go carefully |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
the genuine ones have a nut and bolt under the front end of the step securing the mudflap to it. The pattern ones have a screw that goes into the step from the wheel side.
