Home > Technical (L322) > Oil Suction 4.4 TDV8.
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Can anyone tell me where the oil suction port is for the engine? I need to siphon off a slight overfill and don't want to remove the sump plug.
I have a Pela siphon, but need to know where to stick it!
Post #336177 6th Jul 2015 10:11pm
I think It's just next to the oil filler cap. Small black cap with a circular arrow on it. (Assuming that's what it is for in any case.) the cap twists off and pulls up.
There is no sump plug, but there is a push on hose at the bottom of the sump, which can be pulled off slowly to release a little oil. There is nothing that can't be fixed with a hammer😜😜
Post #336181 6th Jul 2015 10:28pm
There is what looks like a dipstick tube front left with a black twist top Thumbs Up
Post #336190 6th Jul 2015 11:19pm
That said, I’m not sure a Pela siphon will fit down it Rolling Eyes
The tube is very thin! Rolling Eyes
Post #336191 6th Jul 2015 11:20pm
Looks like it's designed to have a connector pushed on the top and the tube itself acts as the siphon pipe. There is nothing that can't be fixed with a hammer😜😜
Post #336192 6th Jul 2015 11:24pm
Never seen the JLR system I’m afraid... Embarassed
Post #336194 6th Jul 2015 11:34pm
stoutgoose
Thanks all, found it. That is indeed a very thin tube!
Post #336223 7th Jul 2015 6:56am
Does your Siphon tube fit? Question
Post #336258 7th Jul 2015 10:06am
stoutgoose
Nope! However problem solved here; I turned the car around because it was on a slight slope and problem solved!
The siphon tube is a similar diameter to the Pela tube, so I think that I could have adapted the end of the Pela with a tube sleeve slid over the end and sealed, and then placed over the engine siphon tube.
Post #336270 7th Jul 2015 12:06pm
