![]() | Home > Technical (L322) > Alternator voltage output.. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Over 14v |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Just had my alternator replaced, did 14 + at start but 13.7 at 2000 rpm with airco etc blowing and the batterylight telling me it was not happy. Now car is happy again. Obviously it seems to be to low and killing your battery also when below 14. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
14.6 |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Are you reading the voltage at battery with meter or looking at voltage though hidden menu on Sat nav screen? |
Bungal Member Since: 27 Dec 2013 Location: Hartley Posts: 44 ![]() ![]() ![]() |
Hi
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
I know mine reads 13.7v in the hidden menu.
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
I am reading it from a meter in the 12v socket in the car as I'm driving.. Would this be an accurate way of telling? There is no battery light on the dash.. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Sounds interesting +1 on how do you access this? ![]() (14.4V using meter) 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
Just a word of caution. If you are going to measure battery voltage you really need to do it accurately given the small but significant differences in voltage that tend to arise.
IIPTool, if left attached constantly reads the voltage output |
Hi, yes your are correct.. i had one of the voltmeters plugged into the cigar lighter and whilst driving was reading between 13.5v-13.7v.. I went and purchased a good quality multimeter today and tested from the battery with the engine running and aircon on etc, the reading was 14.3v-14.4v so quite a difference and seems my cheap incar ebay special is junk ![]() |
Hidden menu, whilst on the home screen, keep your finger pressed on the top middle of the screen for 5 seconds, then press the navigation button, if these have been done right a keypad then shows on the screen. Type in 753 and the screen shows loads of info over a couple of pages.
