![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8595 ![]() ![]() ![]() |
Yes, you will have to find those two, could be in the valve body somewhere preventing it from doing what it should, if you can't find them I wonder if they could get inside the torque converter...
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
thanks for interest, those two missing, are on the table,near bearing but out the image, don't warry,
Today I built three rings like Assembly bracket for pressure down cups springs, but decided leave the old clutch and steel plates
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I don't know how the contact marks on the casing have appeared, but seemingly it's from sideways movement of the main drums? Doubt it's the loose roller bearings. Perhaps the bronze bearing shells show the wear? Those I believe pull out, mine were gold with no damage/wear etc. they look like circular crankshaft bearings, ie one piece. That pump seal I mentioned, pops off the front, even when in situ etc. not the rear of the pump...have you discovered the centre drum with the o ring yet? That I pictured etc? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1003 ![]() ![]() |
If you’ve had issues with reverse then it’s important that you replace O-rings 74.140 and 74.150
this mean that I heve to disassemble D/E another time, just today assembled.
“but IS This normal”
Thanks Phil, your help is like gold
just a quick question here regarding those b clutch pads, I noticed that mine had indeed been scuffed a bit, but not as bad as the ones above, what was the concequence of that?
There’s no consequence as such, and the hub can be reused - the pad wear just gives a useful indication of how far the bearing damage had gone. The critical thing is to dig out and replace the steel washer too as it’s likely to be wafer thin (and therefore razor sharp, so care is required)
well Phil, that's very relieving to know.
today not much time for the box, we have only just begun .... weekend ahead
without your help I would not solved |
bronze bushe outside is ok with the correct diameter, but the other one inside is not possible take size,but it seems a bit worn where the color faded
