![]() | Home > Technical (L322) > How to get windows out |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
when i did my front, i only had to undo the 2 lower bolts and then twist the glass at an angle to get it out..should be the same for the rear i think.. ... - .- -.
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 ![]() ![]() ![]() |
Stan, were the fronts that easy? I've got two to replace in mine, and I've been putting it off as I've not been able to read up on it. Any pointers would be helpful please |
not easy but with a bit of fiddling can be done.. ... - .- -.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Right, still no joy on getting the rear offside glass window out. Have got it down to the bottom of the door as far as it will go but it rests on the wheel arch indentation and is still some 6" too high to access the upper bolt.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
Here you go...
Thanks hay man! Hope your old girl going strong! )Reckon they must have loved our coloured ones the most and so made them better!) |
