![]() | Home > General > why? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
why do the temperature knobs only go down to 16 degrees, what if i want a 10 degree temperature in the cab.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7986 ![]() ![]() ![]() |
In the manuals or workshop docs it states it's not an actual temperature that's achieved, just a target. Or similar words. When I had my air con serviced a couple of weeks ago the temp inside was measured at 8 degrees, which is not on the dial either. All the way cold will blow cold all the time....
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I have to ask why you'd ever want 10'C, Stan?
all down to tractor drivers then |
Yeah, I find removing a coat such a faff. Unzip, one arm off, then the other... BORING!!!!!!!!!!!!!!! Ten seconds of my life I won't ever get back. |
just wondering if its worth a trip to berkshire to slap you with a wet kipper... |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
And then theirs the rain, maybe Stan doesn't like getting wet either.......but then I guess the butler would get wet also |
you're the list as well mike |
You'll have to catch me first....now give us a minute to tack up the horse... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16396 ![]() ![]() ![]() |
Hmmmmmmmm Kippers... Breakfast hmmmmmmm
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Just switch the climate control off and open the windows/sunroof. I suspect the biggest reason they only bottom out at 16deg is the cabins aren't really insulated (like a fridge) so the amount of cooling power required to pull the temperature down and maintain it in summer would be impractical, plus you'd be getting frost bite with the wind chill effect. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6829 ![]() ![]() ![]() |
If we wanted 10 degrees in Scotland we have to put the heater on Stan. So think yourself lucky! |
always cold up there isnt it alan......
