Home > Technical (L322) > Parking sensors not doing anything.
g1968g
Hi
does anyone know what wire is the power supply to the module.
I have the same problem. I was hoping to find water damage but it's dry.
None of my sensors are clicking
Cheers
Geoff Looking for FFRR
Post #335651 3rd Jul 2015 5:48am
Blade74
Australia
I'd be assuming it's the black and the front and back are yellow.
Post #335655 3rd Jul 2015 7:05am
Blade74
Australia
So I got the new module in the mail today.
I plugged it in and when I chose reverse I got one beep and then nothing.
The little park sensor light in the centre column flashed and went out.
If I manually turn it on it flashes and goes out.
So it's not working.
Does the new module need programming or something?
Confused.
Is it just plug and play?
Post #337222 13th Jul 2015 1:47pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Hi,
Yes just plug & play, plugged mine straight in & worked fine.
Sounds like you may possiby have a 2nd issue with a faulty sensor or damaged wiring.
If you use the search at the top there's loads on diagnosing faulty ones.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #337244 13th Jul 2015 5:16pm
Blade74
Australia
Thanks RJH. I've looked through numerous posts.
The strange thing is my parking sensor button only flashes for about 5 seconds then goes out so I can't really walk around and test the sensors for clicking.
I may have to take it to a dealer if I can't work it out.
Post #337295 13th Jul 2015 10:58pm
