![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
Just a question , you think that I can reassembly the box, or I have to replace some other part before.
replacing the countersunk screws in the package F, I found only this, that are M8X25 instead of M8x24 position 77,210
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1004 ![]() ![]() |
Sorry, just catching up after a weekend away.
Yes, the gasket usually ‘welds’ itself to the orifice plate close to the seven screws which clamp it to the duct plate.
You need to remove the old gasket carefully ensuring that you don’t scratch the plate in the process. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I need to double-check but I think this area is machined just to clean up the beam weld joining the drum to the shaft. The A-clutch piston has a corresponding annular cutout cast into its back to ensure that it sits squarely in the drum when ‘off’ and doesn’t rest on the weld spatter. It’s therefore nothing to be concerned about. Phil |
[quote]'
not in mind ![]()
yes I read many forums with the same problem,the best advice is your advice, loosen before removing inside packages, and have muchr weight.
the inner flange measure 6,6mm the hole of the package F measure 19 mm up to piston F then I think it's a risk to mount these, which is why the original are 24mm think Jpat can supply the original ones? and what part number for Torque converter bolts? what's about small cracks above , on D/E clutch drum RRPhil, thanks for coming back to me |
Yes, I agree that your MV3 solenoid winding resistance is a bit higher than usual. Strange. However, the chances are that the solenoid will never get called into use during the whole lifetime of the vehicle. It’s only there in the event of you inadvertently moving the gear selector lever into reverse while travelling forward at speed. MV3 is then activated by the controller to pressurise the end of the reverse gear valve (51.180) so that the manual valve is overruled and the C & F clutches aren’t engaged. MV3 is pulsed on in Park & Neutral, presumably to test it and prevent it malfunctioning due to lack of use. The function of the MV1 & MV2 solenoids (i.e. the other two brown solenoids) is much more critical as they actually activate the gear shifts. Phil |
JPAT have certainly supplied me with the countersunk screws in the past. Their part number is N208 37 01. Phil |
thanks Phil
Phil, I make a table, like your, for free spring measuring , but I haven't references for comparation-
I'm still here guys, hope can help somebody, so after a research, the only thing found in the net,
These are the groups of identical springs :
The transmission is designed to provide limp-home in the event of an electrical malfunction so reverse and 4th do not require activation of the solenoids. Their hydraulic circuits are fed directly off the manual valve connected to the gear selector lever. This is the reason that the main pressure proportional solenoid (the one with the green cap) provides full pressure at zero current and then a falling pressure characteristic with increasing current e.g. if you pull the wires off you get full mains pressure. The black-cap proportional solenoids operate in the opposite direction i.e. zero current = zero pressure. Phil |
yes I know as ZF PARTS CAT
This morning I checked again and just a little difference with the first one
so I think the springs that have more than +/-0.7mm of difference are to be replaced.. I 'm wrong? for example D-A should be 77,9mm but about 1,5mm missing
and D-C spring is over too long,
I can't understand ![]() infact my spring is 43mm Yes I know that is for audi porsche bmw but is the only reference found Anyway on the ZF PARTS CAT only KV-E /55.150 have two different part number
51.060/51.080/51.140 (SV-1/SV-2/KV-D) are for ''ALL''
thank you Phil, really thanks. |
finally the box is completed with new converter
