![]() | Home > Maintenance & Mods (L322) > Is this really a turbo actuator fault........ |
Have you checked the actuator to see if it is sticking? a common problem with them |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
Yes, checked and lubricated some time ago. Didnt seem to be stuck in any way but it's definitely getting worse. Got - 2017 SDV8 Autobiography in Loire Blue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
could be a faulty boost pressure sensor? Definitely seems to drop out rather than decrease slowly. There is nothing that can't be fixed with a hammer😜😜
^ Is that something that can be replaced on its own?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1848 ![]() ![]() |
You have either 1 actuator seized, a wiring issue to the actuator, or a faulty actuator
Thanks Mikey, is this showing at the LH turbo? When the Indy checked it, they said it was the RH (o/s) that was flagging an error? Got - 2017 SDV8 Autobiography in Loire Blue
It is the R/H |
Phew! That's a relief.
You are not measuring boost pressure in those graphs, that is only the actuator position of both turbos.
Thanks Mikey, I do have the actuator repair kit, which is essentially a new actuator arm. Would it be worth doing this before considering the whole turbo! Got - 2017 SDV8 Autobiography in Loire Blue
I can't picture the turbo ATM. No idea what access is like.
Interestingly enough, drove to Liverpool and the problem seems to have disappeared! |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
was probably just the inlet tract clogged up with soot/oil sludge. |
Can't beat the old Italian tune up! |
