Home > Technical (L322) > Price of turbos and fitting via an indie
DaWalley
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Hoping for pointers on the above please
Whilst I sincerely hope it's smthg other than a turbo issue, I think that one has blown on my 08tdv8 ystrdy!
Driving along just fine, engine is warm, hit the kick down to pass traffic and hear a clonk / popping noise and it lost vast majority of power.
It went into limp home mode instantly, drove it back c.1mile, which it struggled with severely.
I'm now sat waiting to get it into my local indie which next opens tomorrow at 8 AM.
As I'm sat here thinking the worse, I was wondering how much this may cost?
I know ithat it could be another fault and t's all if's and but's at the moment, but assuming it is turbo issues, could you guys give me a no BS estimate in replacing via an indie please?[/i] RR Vogue TDV8 08
Post #337902 19th Jul 2015 10:15am
Might be a split hose Got - 2017 SDV8 Autobiography in Loire Blue
Post #337905 19th Jul 2015 10:40am
Check the hoses, as said as you look at the engine the one which tends to go is the one on the top right
see the post i made on repairing them
http://www.fullfatrr.com/forum/topic26843.html
if not it depends on which turbo has gone, one is a much easier job than the other, apparently. the turbos themselves are available for about £900 each. So it is really how long the mechanic thinks it will take to change, I would get him to agree a fixed price for the labour first, incase it turns out to be a complete PITA. There is nothing that can't be fixed with a hammer😜😜
Post #337914 19th Jul 2015 11:11am
DaWalley
Thanks guys. I know what you mean re the hoses. I had one replaced a few months ago but can't recall which one.
However, when the turbo hhise went last time the car didn't go into limp home mode. I just happened to notice the problem due to slight drop in power and black smoke.
This time there were no prior issues and no black smoke. And, due to the engine fault indicator coming on this time I am (hopefully incorrectly) assuming it's more sinister.
Thanks also re the fixed price idea too, will do! RR Vogue TDV8 08
Post #337920 19th Jul 2015 11:20am
It might depend on which hose and the size of the split? Got - 2017 SDV8 Autobiography in Loire Blue
Post #337921 19th Jul 2015 11:25am
ebajema
There is a complete silicon hose set available for the TDV8, if it is a split hose, I suggest to replace the complete set as those silicon hoses are very strong. There is a post on here about the hose sets Smile http://www.fullfatrr.com/forum/topic32550.html MY 2010 5.0 SC Galway green and sand interior!!
Post #337950 19th Jul 2015 1:06pm
Zirconblue
it might not even be split, it might have just popped off and needs pushing back on and the jubilee clip tightening up
Post #337984 19th Jul 2015 4:17pm
neal
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Barolo Black
I have 2011 4.4v8 which has just started smoking on acceleration. My indie guy says 25 hours labour which he has agreed at £1500 and if its seals then £375 or if its the turbo complete then £1500 inc vat.
Post #338552 22nd Jul 2015 5:05pm
^has yours had the turbo drain modification done? There was a service bulletin re smoke on acceleration which involves fitting a scavenger pipe to one of the turbos. Not sure if it would be done foc at a dealer but it is worth asking the question! There is nothing that can't be fixed with a hammer😜😜
Post #338600 22nd Jul 2015 9:03pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
http://www.fullfatrr.com/forum/topic29786.html
Mine was smoking under acceleration. Dealer carried out the drain mod and solved the problem.
Post #338603 22nd Jul 2015 9:09pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
With a poink/clocnk.....
Doesn't seem good.
The hoses problem issue, its just a boing/warning on the dashboard.
Mechanical noises....pray my friend, pray.... and in the end pay... Censored
Post #338700 23rd Jul 2015 3:46pm
