Home > Maintenance & Mods (L322) > Radiator Flow Test
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Radiator Flow Test
I found a PDF for the drain down radiator test to see if the lower section is clogged. Problem is that the pictures are low quality. Anyone have a source for better pics or added input? I am also unclear if the cause of transmission cooler failure is only from radiator clogging or can the transmission cooler fail on the transmission fluid side? Thanks.
Post #338260 21st Jul 2015 1:33am
This is my old rad, removed from car, hose in top hole, this is the flow from the bottom feed to the gearbox cooler
This is the same with a new rad...
Trans cooler can fail internally and put water in gearbox, it can also get blocked with old dirty oil and the pipes often collapse internally and block flow...
If you having gearbox overheat problems I'd do the lot, new engine rad, new oil cooler, new oil cooler, oil cooler thermostat and manifold and new cooler lines...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
-Click here for Thread-
Post #338295 21st Jul 2015 11:51am
doclees
Thanks. No issues yet and I want to be proactive on these things. 120k miles on it now. PO was not first owner and doesn't know if it was ever changed.
Post #338350 21st Jul 2015 3:13pm
