Home > Maintenance & Mods (L322) > L322 air suspension pipe worn through
SO3isme
Hi, I am losing air through a leak in one of the blue pipes on the air suspension (2005 SC). It's at the underside OSR of the car not far from the compressor. Does anyone know of a repair process rather than replacing all the pipework, as is being recommended to me?
It seems possible that one could splice in a new section or just cut the pipe at the break and fit a connector?
Thanks in advance.
Post #338337 21st Jul 2015 2:25pm
proser
something like this :
http://www.ebay.co.uk/itm/Nylon-Pneumatic-...1428401633
Post #338351 21st Jul 2015 3:15pm
SO3isme
Yes, exactly. Just wondering about sizing? I guess you can measure the internal and external diameters. I don't have the car here at the moment so I can't do this right away. Also, access is a bit of an issue.
Post #338353 21st Jul 2015 3:24pm
SO3isme
Also, anyone know what the maximum air pressure is in the system when fully working?
Post #338354 21st Jul 2015 3:26pm
proser
found this :
The Range Rover L322 uses an Electronic Control Unit to control the air suspension system. An air compressor unit supplies the suspension reservoir with a maintained pressure of up to 14 bar (200psi). This air pressure is then used to inflate or deflate the air springs as required.
But not sure if that means that 14 bar is passed out to the springs
Post #338357 21st Jul 2015 3:34pm
SO3isme
Ah. Looks like the plastic ones are not up to spec.
I did find this:-
http://www.advancedfluidsolutions.co.uk/6m...1964-p.asp
Post #338359 21st Jul 2015 3:47pm
proser
I think they will do it on the pressure front, just need to get the right size for the piping
Post #338362 21st Jul 2015 3:56pm
SO3isme
This seems more informative:-
http://www.ebay.co.uk/itm/Range-Rover-Vogu...1137752607
Post #338367 21st Jul 2015 5:37pm
Might help
http://www.fullfatrr.com/forum/topic15626-15.html There is nothing that can't be fixed with a hammer😜😜
Post #338368 21st Jul 2015 5:39pm
SO3isme
Is similar. Thanks.
Post #338371 21st Jul 2015 5:49pm
Ha, I remember my old post well... and the cold...
Yes, 6mm push fit connectors are what you are after. I bought mine from a local Compair outlet. Previously..
Post #338379 21st Jul 2015 6:09pm
SO3isme
I have ordered the kit with a section of pipe and 2 connectors. Hopefully, that will cover any eventuality.
Accessibility will be my next issue......
Post #338382 21st Jul 2015 6:22pm
SO3isme
The parts came today and I was able to cut out about 10mm of worn pipe and then insert one of the straight connectors.
All seems to be well! Access was a bit of an issue and I had to resort to scissors to cut the pipe as my other cutters would not reach into the available space.
Post #338683 23rd Jul 2015 3:11pm
That was a lovely cheap fix... top job...
Thumbs Up Pete
-Click here for Thread-
Post #338706 23rd Jul 2015 4:21pm
Thumbs Up Good job .
Post #338713 23rd Jul 2015 4:35pm
