Home > Technical (L322) > L322 tailgate /load space lights
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
I'm sure I've read somewhere (but can't find it in search) ....
We are taking dogs out and will be parked up with tailgate open. So we need to turn off the tailgate and load space lights so we don't end up with a flat battery! They don't seem to go off after 15 mins or switch off with the ceiling light switch which operates the rest of the interior lights.
It's a 2003 l322.
Help! Cheers!
Post #339013 25th Jul 2015 11:41am
Change the bulbs for leds?
Post #339033 25th Jul 2015 2:46pm
They should switch off after 16mins, mine certainly do, if they don't do what NDF says, LED bulbs and you can leave them on for hours without effecting the battery... Pete
Post #339039 25th Jul 2015 3:53pm
miggit
^^ Days even! FYI they are NOT canbus Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #339101 25th Jul 2015 11:15pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
My wife leaves the tailgate open when doing the horses with the dogs in the back of the rr and the light stays on, can you get led's from any auto store?
Post #339103 25th Jul 2015 11:25pm
Hold the interior light switch button for 10 or 15 or even 20 seconds and the interior lights will flash once then stay permanently off until you reverse this procedure to switch them back on Thumbs Up
Hope that resolves your issue Thumbs Up
Post #339108 25th Jul 2015 11:58pm
miggit
This is the sort of thing that you want
http://www.ebay.co.uk/itm/2-X-9-SMD-LED-50...19f2241631 Yesterday I couldn't spell Engineer... Today I are one!
Post #339110 26th Jul 2015 1:24am
sako243
Found a quick and easy way is to push both latches shut manually (one on tight and one on top tailgate). Makes the car think the boot is shut. If I remember correctly might only need the top. Just push the button to unlock again. Ed
Post #339111 26th Jul 2015 2:06am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I changed mind to LED for the same reason. Turning off the lights only turns the cabin lights off on mine, not the tailgate lights Sad
Post #339117 26th Jul 2015 8:03am
PaulTyrer
H
Thanks Craig, will try that
Post #339130 26th Jul 2015 8:53am
You can use an iiD Tool to stop the interior lights coming on if the tailgate is open , if that helps . 2008 MY Supercharged
Post #339146 26th Jul 2015 10:23am
axles correct,
Post #339152 26th Jul 2015 10:47am
Fish
Cool, now I just need my iid tool to arrive Big Cry
Post #339156 26th Jul 2015 11:34am
H
Your welcome Paul Thumbs Up
Post #339235 26th Jul 2015 7:57pm
SCPB
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
This is really helpful, I was wondering whether I could prevent the interior lights coming on with the tail gate open. I have just been outside with my IID BT and gone into the CCF files but I can't seem to find that option, come to think of it I can't find the other options Stan has highlighted, window closing, sun roof closing etc. Is it under CCF Body control? 2010 5.0 SC Autobiography
Post #339437 27th Jul 2015 9:41pm
