![]() | Home > Maintenance & Mods (L322) > Slight vibrations at 2000-2300 rev range 3.6 TDV8 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Sounds more like an dirty injector problem, run a couple of tanks with injector cleaner and see if it improves. |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 258 ![]() ![]() ![]() |
Will try and report back! Thank you! |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 ![]() ![]() ![]() |
I had the same thing, the vibration was very slight , but definitely there around 2000rpm.. The vibration pretty much disappeared after I had the transmission mega flushed, and completely disappeared when I changed the diff oils.. Maybe something to look into.. How many miles has yours done, and has it had a transmission fluid change.. |
