Home > Maintenance & Mods (L322) > Viscous fan conversion
Page 1 of 3 123>
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
Breaking down my 3rd viscous fan, I am now thinking about replacing it by an electric fan.
I know some of you guy's are driving around with the viscous removed but I sometimes do some heavy towing so i would like some cooling. Anyone did this conversion? cars on the side;
Audi A8 W12
560 SEC AMG Widebody '86
500 SE '86
Post #339357 27th Jul 2015 4:44pm
Just under halfway down this page.... Jaguar X type fit very well
http://www.fullfatrr.com/forum/topic24082-90.html
Thumbs Up Pete
-Click here for Thread-
Post #339360 27th Jul 2015 4:57pm
djharm
Looking good. Don't know if I can find one from a X-type on short notice.
Was looking at this thermostat. cars on the side;
Audi A8 W12
500 SE '86
Post #339369 27th Jul 2015 5:37pm
This guy is selling six...
http://www.ebay.co.uk/itm/Jaguar-X-Type-Pe...3f16d64b54
If you haven't changed the thermostat then you will need an adjustable fan controller, the fixed ones come in far too early for the temp these engine run at... Pete
Post #339377 27th Jul 2015 6:08pm
djharm
It is advertised as ajustable from 70 to 120 degrees Celcius.
From the Jaguar I will need all the electronics as well?
Cables and plugs (obvious) and also the fan controll module?
how did you connect all that? Very Happy cars on the side;
Audi A8 W12
500 SE '86
Post #339398 27th Jul 2015 7:50pm
The one I got came with a soft start relay, otherwise use an 80amp relay, direct fused supply from the battery and an ignition switched supply for the control feed...
This is the wiring diagram for the Jag
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #339430 27th Jul 2015 9:18pm
djharm
Thanks. cars on the side;
Audi A8 W12
500 SE '86
Post #339432 27th Jul 2015 9:24pm
Zirconblue
The fan control module on the X-Type is fixed to the fan housing if i remember correctly.
Post #339453 28th Jul 2015 12:05am
djharm
Looking at the wiring diagram, I was wondering what battery input 2 and 3 are. one from the thermostat and one from the car ignition I assume.
Which one goes where? cars on the side;
Audi A8 W12
500 SE '86
Post #339585 28th Jul 2015 6:36pm
Wht/Grn to feed from controller
Brn/Grn to permanent 12v via 80amp fuse
Blk to Earth, same rating as wire to Brn/Grn
Wht/Blu not needed, just tape it up... Pete
Post #339598 28th Jul 2015 8:43pm
djharm
While gathering parts, I removed my viscous fan. I now see a significan drop in temperature on the highway. Looks like a broken egr thermostat. Had this problem before so I replaced it about 6 months ago. Maybe it took a beat while removing the viscous fan. Or am I missing something? cars on the side;
Audi A8 W12
500 SE '86
Post #340098 31st Jul 2015 12:31pm
miggit
Pete, Buddy got to ask, have you got a fan kill switch? Only ask as it was a must add on for Jeeps with an electric fan conversion to stop them coming on when swimming, and drowning the engine. Yesterday I couldn't spell Engineer... Today I are one!
Post #340137 31st Jul 2015 6:32pm
Oh yes, wired into a very annoying buzzer so you don't forget to turn them back on when out of the water.... Pete
Post #340241 1st Aug 2015 11:26am
miggit
Is that like those alarms that you hear on the war films just before the submarine dives Wink
Bearing in mind that I don't want to go sailing in my ffrr, but I do use it for some serious towing, in your opinion, would you think this is worth thinking about? I'm very keen to extend the life of my ffrr as long as possible, but I also don't have a great deal of dosh to throw at it. Yesterday I couldn't spell Engineer... Today I are one!
Post #340243 1st Aug 2015 11:36am
I changed mine because the viscous fan was not working and it was cheaper than a new one of them, it's also handy when wading but modern fans blades don't tend to break when they hit water and the engine is pretty water friendly as well...
It's also easier to remove than the viscous fan....
Doesn't make it run cooler but it does move a lot of air at tickover if you have problems with yours overheating... Pete
Post #340248 1st Aug 2015 12:17pm
Page 1 of 3 123>
