Home > Technical (L322) > A/C icing, evaporator temperature sensor?
miggit
Hi all, got issues with the A/C, the temp goes up and the air flow drops. From what I can make out it's the evaporator icing up, also I regularly get vapor trails coming from the centre vent (mini clouds). Has anyone got any thoughts Question I also seam to be leaving a constant trail of water, sometimes when I pull away the next morning there is still water on the ground, and it hasn't rained Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #339479 28th Jul 2015 10:07am
i'd go and see a doctor re that last one .. Laughing ... - .- -.
Post #339480 28th Jul 2015 10:08am
miggit
You'd know all about that bud Laughing Unfortunately Stan I was referring to the ffrr not me, I haven't quite got to the dribbling age just yet Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #339482 28th Jul 2015 10:12am
Laughing
thoughts on this , is the re-circulate button on/off , does its make a difference if switched the other way? ... - .- -.
Post #339485 28th Jul 2015 10:14am
miggit
Censored I knew that this was going to get technical, re-circulate button?, I'll have to read the Censored instructions now Evil or Very Mad Thanks Mate.
In all honesty I just press the auto button, and both lights are on, the dot and the dash. I didn't want to mess around with a system that appeared to be working, in case Sod the Almighty intervened, lets face it a ffrr is a financial time bomb waiting to go off. And if it ain't broke leave well alone Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #339488 28th Jul 2015 10:21am
miggit
Question Question looked at the handbook, it isn't very clear as to what's what...... So how many lights do I need showing on the button below the snow flake? Embarassed Yesterday I couldn't spell Engineer... Today I are one!
Post #339489 28th Jul 2015 10:29am
miggit
Re-circulate is off, no lights at all so I will take that as fresh air, which should be the least likely to cause icing, and clouds forming in the car Thumbs Up And this is now the point where I say HELP!!!!!!!!!!!!! Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #339605 28th Jul 2015 9:29pm
I would say it is low on gas, had two cars in the past that made clouds out the dash and both were fixed with a regas.... Thumbs Up Pete
-Click here for Thread-
Post #339608 28th Jul 2015 9:35pm
miggit
Sounds reasonable to me, try a re-gas before a dash removal, way easier to achieve Thumbs Up
Thanks Buddy, hows life now your fully bionic? Yesterday I couldn't spell Engineer... Today I are one!
Post #339619 28th Jul 2015 10:01pm
If you had an IID tool you could check it yourself.... Whistle
Hips are great, right knee is well fubar'ed, exercises for the new hip made the knee worse, Rolling Eyes should find out in a couple of weeks what they will do about it....
Much less pain overall than before them though so going in the right direction..... Thumbs Up Pete
Post #339634 28th Jul 2015 10:32pm
miggit
Dam Pete, your going to end as modded as your ffrr Wink
Glad to hear that your on the mend, and I can see from your posts it hasn't stopped the Aquatic Rover development, keep up the good work Bud, and I look forward to the winch. Although I'd prefer to put it at the other end. Just can't justify the stupidly expensive price the stealers want for the kit, and I haven't found any alternative.
£3000 for a £700 winch and a bit of steel is too pricey for me. Yesterday I couldn't spell Engineer... Today I are one!
Post #339639 28th Jul 2015 11:02pm
will be having a front one as well.... Thumbs Up Thumbs Up Pete
Post #339641 28th Jul 2015 11:04pm
miggit
Ooooooooo Pete, just found this
http://www.ebay.co.uk/itm/Range-Rover-L322...2ee37fb613
But I am looking at it and thinking that it may be a bit defeatist, as it would appear to knock all the ground clearence, the L/R unit has the inner PDC sensors in it, that one sits below Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #339642 28th Jul 2015 11:13pm
Yes....... lose about 6 inches of ground clearance with that.... mind you at least you'd have a winch to get you unstuck.... Rolling Eyes Rolling Eyes
Mine will be a bit more user friendly..... Pete
Post #339643 28th Jul 2015 11:23pm
miggit
Just stumbled on this if your going the D I Y route, might give you some idea's
https://www.facebook.com/media/set/?set=a....amp;type=3 Yesterday I couldn't spell Engineer... Today I are one!
Post #339646 28th Jul 2015 11:32pm
