![]() | Home > Technical (L322) > SC 4.2 Brake adjustment |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
You can't adjust the front brakes.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
^ as mikey said there is no adjustment in the front discs and pads, they are self adjusting so to speak. The pads wear, get pushed closer to the disc, to compensate more fluid from the reservoir enters the system and the reservoir levels drop.
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 ![]() ![]() ![]() |
Thanks northernmonkeyjones and Mikey.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
Have you bled your brakes at all, or checked that the calliper isn't seized? Got - 2017 SDV8 Autobiography in Loire Blue
Mmmmm since I have some family living in Gauteng, I'd better see if I can help here |
@Alan: I know some work had been done on fhe brakes when I purchased the vehicle 4 months ago. Not sure if it had been bled.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
So to summarise it can be caused by;
Thanks Zirconblue.
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
If the brake pedal feels OK then i would check the discs first as its very hard to sop with glazed or rusted discs. If the pads are shiny then they wont stop you. What doesn't kill you is just bidding it's time. |
