![]() | Home > Technical (L322) > 4.4 tdv8 brakes |
They should be pin sharp! I drive them often, all different ones and they usually feel more positive than 4 pots! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Will be new discs and pads then!
well they have changed the design of the calipers so the bolts don't bolt straight to the calipers any more, they bolt to an steel insert on the calipers, so they are now |
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 ![]() |
Hi
Much better after swapping the discs and pads at the front! There is nothing that can't be fixed with a hammer😜😜
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
I need to do the front discs and pads on my 4.4 TDV8. Is there anything that's going to stump me compared to my old TD6 ?? Any help appreciated. 2012 4.4TDV8 VSE
No, it should be fairly straight forwards.
Mactech Member Since: 27 Jun 2015 Location: Biddulph Posts: 126 ![]() ![]() ![]() |
Not really!
Thanks. Dealer wants £680 front discs and pads!! 2012 4.4TDV8 VSE
PS will a normal caliper piston spreader deal with the six pots??never tackled a brembo caliper. Have them on my Porsche and not needed to do them yet. 2012 4.4TDV8 VSE
No.
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I've noticed the same on my 4.4 TDV8 and without point of reference (this is my first FF), I have been putting it down to the weight of the vehicle etc. Although they stop well enough, they don't have as much initial bite as I expected from six-pot brakes...discs and pads are in good fettle. |
Yeah, my Supercharged is like that too, almost as if the servo is not rated highly enough. However, give them a mighty stomp and the car stops on a sixpence. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Im chuffed to bits with these calipers and discs Craig fitted to this one before i brought it and im glad i never brought any other one as the few ive driven dont come close to power or quietness for a diesel |
