![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 258 ![]() ![]() |
IIDTool Updater v3.5 had worked fine up until I updated from Win7 to Win10.
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
I struggled a bit with this myself - You have to be logged in to access the download page at Gap - www.gap-diagnostic.com ![]() |
Thank Eirik, I thought I was going mad when I couldn't see it |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
LCM odometer values: we will look it up. Sometimes, the ECU do not support it but will answer with a dummy value. http://www.gap-diagnostic.com/
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
can a IITOOL for a 2002-2005 ,be used on a 2007 2007 tdv8 se ,stornaway grey |
If it's an IIDTool BT then yes, else (non BT) it will not work unless the firmware is changed (55 GBP) http://www.gap-diagnostic.com/
Really beginning to wish I had changed to a BT version when you guys offered me a trial version |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Le Meilleur - He certainly lives up to his name. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
^^^+1 |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 ![]() ![]() |
Hi just wondering if a menu tree is avaible for the IId tool so i can see what i can all do to diagnose my fuel injection fault, how can i check fuel preasure and injection pulses etc to fix it, also i quite often get funny characters on the screen and have to power of the tool and repower, it happens mainly when i go into engine ecu and try and read the error codes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35826 ![]() ![]() |
menu tree is on the GAP site,
Always a pleasure |
Bluetooth up date arrived today from GAP . Oh Yay |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
The support from GAP is amazing. If more companies offered 50% of the support that GAP give things in general would be much easier. Can't praise them highly enough.
