![]() | Home > Maintenance & Mods (L322) > Radiator Bottom Connector Coupler Fitting |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I have just been replacing my radiator.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8570 ![]() ![]() ![]() |
It does only fit in one position and it can help to remove the metal fixing clip, push it on then push the clip back on...
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I've had this before on a BMW and it wasn't helped by being a pattern rad rather than OEM which I suspect the fittings were a little larger / off size. I lubed the couplings with coolant and it is quite oily to the touch and obviously won't contaminate the system - worked well. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'd agree about washing up liquid being salty, but it washes off easily by sloshing some water over it with a watering can or hose. Any tiny bit of salt that's left after that will be insignificant to the amount that will be thrown at it come winter. |
There is actually a fare bit of alloy that is within the fitting that you couldn't wash it out from, and if you got even a small amount in the rad you will end up with suds in the header tank...
Thanks to everyone for chipping in with solutions and so quickly as well |
