Home > Maintenance & Mods (L322) > Labour Saving Devices
supershuttle
After many years of telling SWMBO that the potions and gadgets she buys that are supposed to help with domestic cleaning tasks are a waste of money today I discovered the Clay Mitt. It didn't get everything off first pass but the noise showed where the big tar spots were so I could remove them with a clay bar. I didn't use any special sprays or potions just the Auto Glym shampoo to keep everything moist during washing and claying operations and then rinsed of with hosepipe. I still need to do the lowest panels because I ran out of time but the mitt clearly showed they need a bit more work. Why I have I not found this labour saving device sooner , will I have to confess to SWMBO that I might have been wrong? Rolling with laughter Geoff
Post #341648 10th Aug 2015 2:34pm
Zirconblue
they're magic aren't they!
Post #341653 10th Aug 2015 3:09pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
This kind of thing?
http://www.detailingworld.co.uk/forum/showthread.php?t=330602
Not seen these before - looks good Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #341664 10th Aug 2015 4:28pm
supershuttle
That is exactly what I bought - 3 for 2 at Halfords although I only bought 1 mitt, a bottle of AutoGlym shampoo and some interior dashboard cleaner.
Paid for the two most expensive items as you can mix and match. Geoff
Post #341675 10th Aug 2015 4:58pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Is it worth the effort getting detailing spray or would normal shampoo/water be enough to lube the paintwork? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #341687 10th Aug 2015 5:39pm
Andy B
Read earlier somewhere on here that the Mitt is fine with car shampoo. With the Clay Bar you need the 'lube' Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #341689 10th Aug 2015 5:59pm
supershuttle
I just used the Shampoo as a lubricant, even for the clay it seemed to work. Just made sure there was plenty on, I do have the detailing mist (it came with the clay bar) but found I didn't need it. Geoff
Post #341707 10th Aug 2015 6:51pm
Bilt Hamber Auto Clay requires only water as a lube Thumbs Up
Post #341719 10th Aug 2015 7:53pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Excellent things clay wash mitts particularly if you don't have the time or inclination to use clay bars. You can buy the special expensive lubricants but copious use of a good car body shampoo is just as good.
Post #341723 10th Aug 2015 9:02pm
Zirconblue
The detailing spray you can use with it is just shampoo with a bit of wax in it.
Post #341741 10th Aug 2015 11:08pm
Just ensure you wash and rinse the car first and then clay with either the mitt or the bar. Do NOT use the clay mitt to wash and clay at the same time as you'll grind any dirt into the paint.
The mitt can save time but I found the clay to give far better results for the additional extra effort. Plus, with the clay bar, you can re-mould the bar once it gets dirty. You cannot do this with the mitt, but you can at least rinse it. Si. <This is my name.
Post #341754 11th Aug 2015 5:36am
