![]() | Home > Maintenance & Mods (L322) > OFF ROAD Slow 50kph (30MPH) Message |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 777 ![]() ![]() ![]() |
My 2003 TD6 has given this message a couple of times and not sure why. I use the car daily for work and one visit I do is on a short rough track. When I leave the track onto the bitumen once I hit about 60kph I randomly get a Bong with the OFF Road slow 50 kph message. No Dramas, everything works OK, once the bong repeated itself after a minute but other times just once then its gone and only does it again until I leave the same track. It does not do it every time. I am wondering if the suspension extends a bit on the track and is slow to level back down. Is this a known problem, is there a known cause. Is it normal? I can find nothing searching this forum or elsewhere.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3204 ![]() ![]() ![]() |
Not sure if this is correct or applicable but, on mine (touch screen), you can set the nav for on road or off road. If yours is set for off road it may be recognising leaving the road and acting accordingly.
Interesting , so you are not putting the car into off road height right ?
Axle,, I am not putting the car into off road height or low range. All the suspension settings work perfectly as the low / high selector. The car just seems to think its in High / off road mode when I hit the tarmac. The suspension height lamp is in normal mode (centre). The track I use is only 100mtrs long and not in any way hard, I would drive it in a ford fiesta if it was not mine. My thoughts are with the bit of flexing the suspension raises a bit then is slow to lower back. 2007 TDV8 VSE
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 ![]() ![]() |
Mine does this occasionally as well, I think its just if a wheel moves slightly more than the normal ride height tolerances it will trigger the height sensor while its correcting its height - such as a sharp road camber angle change or a transition from a deep rut/channel - as it corrects itself straight away I don't tend to worry about it and only seems to happens at low speed. Current Fleet:-
I will try raising the suspension when next on the track. I will also have a look at the Exhaust on the compressor when I get 1/2 hr. Thanks for the input. 2007 TDV8 VSE
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7962 ![]() ![]() ![]() |
Mine does exactly the same all the time when off roading, it will be in normal height and bong the message... I went through all the settings and live data streams and have concluded it is as has been guessed above... the poor little thing thinks the car is a bit high and lets you know...
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I suppose in effect what it does is automatically detects it's on rough ground and raises the suspension, in the same way that it lowers it on a smooth motorway at speed. (in a roundabout sort of way)
The early ones certainly don't raise the level automatically and they have no way of "knowing" if they are offroad or not, the later ones do and can adapt to different surfaces...
Sorry I didn't really explain myself well. What I meant was that while it doesn't do it by design. Lots of axle articulation has the side effect of raising the average level of the suspension. So it's like a crude way of the suspension self raising on rough surfaces. When the road smooths off it realises it's too high so settles down again. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 417 ![]() ![]() |
Page 60.10 of the WSM under cross link valve:
What it doesn't say in the manual is that the cross link valves only go live when you are in raised off road height... at least, mine don't...!!!! Pete
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
I do alot of off road driving and never come across this, the cross link should come on in standard height too. |
I completed my daily off road adventure today but this time put in high mode. When on the tarmac again 100mtrs later I set it to std height and continued on with no messages or bongs.. As others seem to have the same warnings I will just ignore it in the future. 2007 TDV8 VSE
