![]() | Home > Technical (L322) > Auto dimming door mirror glass - how to they work? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
That's a tricky one bud, I know that the sensor that triggers the auto dim is in the rear view mirror, and you should have 2 pairs of wires going to your mirror glass, 1 pair for heating and the other for dimming. Can you not put a meter on the wires to see if you have any voltage there at all? Should be easy to determine which are the heating wires by turning the heated screens on.......... how you trigger the auto dim is anyones' guess, imagine that would involve darkness / inside with out lights, and torch to shine at the rear view and your head lights on |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Yeah The sensor seems to work ok as the interior and passenger side mirrors dim fine.
The only other way is to remove the mirrors and try them on the opposite sides of the car, at least you'd know if the fault was in the loom or the mirror |
yep definitely the glass, passenger side works on both sides, the (new) drivers side one doesn't work on either side.
I was already thinking about how i would strip down the mirror head to repair the wires. It's annoying though, as the old glass fell to bits when i took it off. So hopefully Island have another one in stock and i can just swap it there and then. |
Well tried a second "Eurospare" mirror from Island 4x4 that doesn't work either. I would assume they're not much cop! So will be taking both of them back and getting a genuine one. |
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 ![]() ![]() ![]() |
@zircon, mine has the same mirrors and investigation put me towards ebay but i folded and got my mirror glass from my local MD at £100 ish quid. It at the time was a bit cheaper than the site sponsers could do it for but not by much. My MD also fitted for £10 with the breakage being their problem if it happened |
Yeah my local dealer quoted me just over the £100 mark with the discount. For the sake of £40 i thought it was worth going with the pattern one.
I would have been happy to fit one myself, quite capable of stripping and refitting an engine (subaru not FF) but like most don't want to throw £100 down the drain. Imo for the mirror it was worth the little extra for someone else to cover the cost |
No i get your point, wasn't suggesting you couldn't do it yourself. I might just ask the parts bloke to put it on for me. They're pretty helpful. |
Sorry Zircon did not mean to come across any other way than helpful. I think all members could do it just sometimes it's worth a few quid not to have any stress and the part you have paid for is covered despite anybodies butter fingers |
exactly and you get to smirk a little if they break it. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8820 ![]() ![]() ![]() |
Must say they were one of the first things to go on mine, mine were flat and left a massive blindspot you could lose a 7 1/2 ton lorry in...!!!!! I got some cheap as chips normal heated ones with a curve and the blind spot has totally gone, very easy to change and they still are fine 18mths later...
