![]() | Home > Technical (L322) > heavy steering started |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
i had the servotronic valve go on my td6 Matt and the symptoms were as you describe..
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
^^ I'd look at that pesky servotronic valve thingy, or cancel your gym membership as you is going to get a free workout ffrr styley |
Stan, Matt face lifted his early model 4.4 V8 Petrol car to 2012 spec so his is an early model NOT a 2012 as per his details...
thats what i thought Craig but the little car says 2012. |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
I have a valve still for sale |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
Dam only just seen this, have ordered one from Dan |
Did some more testing this afternoon before ordering the servo valve, I monitored the servotronic PWM % on my faultmate to see if I could see anything and with the engine off I got various readings and when I started the engine I got various reading however after about 5 seconds the value dropped to 0% coninusilly so I'm hoping this indicates is faulty. I also removed the drivers front wheel and checked the valve wiring for damage and all looked good in fact the connector looked in brand new condition.
Bu66er , think I'm way cheaper than Dan ! Hope it fixes the problem. |
Just replaced the BCM for a brand new one and the heavy steering issue has gone, everything is working perfectly and the steering feels better than ever!
So was it the valve as well, or just the on set of dementia in the BCM? Yesterday I couldn't spell Engineer... Today I are one!
My issue was just with the BCM being faulty, the valve that I removed was in perfect working order. I have kept the new valve on as the old one was 12 years old.
| All times are GMT |
