|  | Home > Maintenance & Mods (L322) > IID with engine running |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | It will not work with the engine running sir  | ||
|  12th Aug 2015 9:46pm |
| Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45      | Thank you kindly ill get the charger topped up first then  | ||
|  12th Aug 2015 9:49pm |
|  12th Aug 2015 10:00pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    |
 Just don't leave it connected unless it has a supply mode.  Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver   | ||
|  13th Aug 2015 9:14am |
| Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45      | Excuse my ignorance but what do you mean buy a supply mode? | ||
|  13th Aug 2015 8:30pm |
| espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86      | many of the battery maintainers (like some of the ctek range) have supply mode, a regulated 13.6v output which is useful to retain radio memory when the battery is removed | ||
|  13th Aug 2015 8:56pm |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | As above, but the function is also of great use during ECU flashing.
|  14th Aug 2015 7:38am |
| Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45      | Thanks for clearing that up guys, so i take it if i purchase a CTEK MXS 7.0 that will do the job?   | ||
|  14th Aug 2015 7:52am |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473    | The BT module is quite a long flash, and they're quite fragile, so I would be inclined to go for the jump leads option, if possible, or a more powerful charger. The MXS 7.0 would certainly help though, vs the battery alone. Obviously, you'll understand, I can't make any guarentees.  | ||
|  14th Aug 2015 8:21am |
| Posting Rules
