![]() | Home > In Car Electronics (L322) > after contact 12v & inside 12v |
Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
as for gps, hence my will to put it behind the plastic grill for better signal.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
You could always use a device such as a power magic pro box, that I bought along with my Blackvue. This ensures that the device switches off should the voltage fall below a certain threshold and so not drain the battery! Piggy back fuse off a permanent live supply in any of the fuse boxes. Previous cars:
Ok, I just understood that the courtesy mirror proposal was for the gps... 2008 TDV8 VOGUE - Buckingham Blue on Sand |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
I had that tracker you linked to above several years ago in a vehicle, it wasn't bad but has an internal GPS and phone aerial, this one is much better and it's what I have fitted... signals are much better even with the aerials buried within the car, it has loads of extra features but if you use it as a straightforward tracker you only need a permanent 12v and an earth.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
If you are fitting a GPS, it will need clear line of sight to the sky, while you can cover it with the dash board etc, it will not like you much if it has any metal above it, and probably refuse to function. They are normally placed behind the dash below the windscreen, so that it can receive the signal from above without the roof or the bonnet shielding it, Oh and keep it away from speakers |
Ok thanks for the link, I'll keep you posted about how installation and function of the gps works.
