Home > Maintenance & Mods (L322) > Lower Control Arms Changed
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Hi all,
I started noticing a knocking noise from the front drivers side, mainly when going over speed bumps and such at slower speeds. At first I thought I was imagining it but it got worse and then started screeching and creaking. As soon as I pulled into the garage he knew what it was as he had heard me coming Shocked
I have now had the lower arm controls replaced but she feels a little bit harsher than before. I don't know if it's just my imagination but it's a bit like too much air in the tyres. There is also a very very slight vibration through the steering wheel around 50mph.
I'm going to check the tyres pressures later although I don't see why they should have changed. Is there anything else I should check or anything that should have been done after replacement?
She doesn't pull either side and the steering wheel is centred but could the tracking be out slightly?
I can't shake the feeling that she's just not quite right, or is it just me Question
Thanks
Post #343097 18th Aug 2015 2:00pm
Zirconblue
It's always a good idea to get the tracking checked after replacing suspension components. They're all made to a tolerance, but the tracking might have been adjusted while the originals were slightly worn.
If it's never had one done, i'd recommend a full 4 wheel computer alignment, i've had it done on my Range Rover and previous cars and it's made a massive difference to the driving experience each time.
It might all settle down in a few days, or it might just be that it was so sloppy before and for so long now it feels tight!
Post #343100 18th Aug 2015 2:13pm
supershuttle
I already had the passengers side done just before I sold you the car, so I suppose drivers side was only a matter of time. Geoff
Post #343106 18th Aug 2015 2:51pm
Check with the garage that they tightened the bolts from arm to subframe with the car on the ground at standard height, if they did it on a lift and tightened them with the wheels hanging then the bushes will be wound up and can give a harsh ride... Pete
-Click here for Thread-
Post #343116 18th Aug 2015 3:40pm
Fish
Thanks guys. I'll check with the garage tomorrow then maybe look at wheel alignment,
Is the system kwik fit use any good?
Post #343142 18th Aug 2015 6:41pm
Zirconblue
It depends what they have, most tyre places just have a basic 2 wheel laser alignment system.
Some (including some Kwikfits) have a computer based one, where flags are fitted to the wheels and an over head sensor at the front of the ramp calculates the wheel caster, camber and toe in/out. So they can adjust both the front and rear tracking (toe in and out) as well as the camber (how vertical the wheel is) and caster, (the self centreing effect). they can also make sure the adjustments are even on both sides.
Some people say the Hunter system is better than the Hoffman one, which is better than the John Bean one, but really i think they're all just as good, it just depends if the bloke operating it knows what they're doing and if they can be bothered to spend the time on it.
On my previous Jaguar it made the car turn in better, gave me another 2mpg, ran straight as a die and stopped all the uneven tyre wear. On the Range Rover it's corrected some tyre wear and it definitely feels more predictable when cornering.
Normal 2 wheel is usually a free check and £25ish to adjust it. Proper 4 wheel is normally around £80ish.
Post #343168 18th Aug 2015 7:53pm
Fish
I've not spoken to the garage today but noticed that the car seems to be a little off level when parked at work. At first I,just thought it was the way I had parked but I looked on the info screen and the level indicators looked out of line and when driving they seemed to keep changing. I plugged my iid in all 4 wheels had different settings. I've balanced them out and it looks and feels a bit better now but still not as I remember it.
Post #343348 19th Aug 2015 8:22pm
The wheels should have different settings, no two sensors are the same... Did you do the levelling as per GAP's instructions?? Pete
Post #343352 19th Aug 2015 8:44pm
Fish
Embarassed no I didn't, I'm a man I don't read the instructions Embarassed
I have done it properly though and made some adjustments. Thumbs Up
Post #343493 20th Aug 2015 6:41pm
Thumbs Up Thumbs Up Pete
Post #343494 20th Aug 2015 6:47pm
Fish
Sorry Haylands, I forgot to thank you for the tip Thumbs Up
Post #343497 20th Aug 2015 6:57pm
No problem mate, glad you got it sorted... have you found out if they did the final nut tighten on the ground??? Pete
Post #343498 20th Aug 2015 7:36pm
Fish
I'm going to call in and see them today.
Post #343537 21st Aug 2015 5:26am
Fish
I finally got this checked as the car needed another service, 2nd in 6 months Shocked , and I asked the garage to check the suspension. They loosened it off then dropped it back on to,the wheels and tightened it back up then checked the tracking and it feels,much better.
Thanks for the tip Haylands. You were spot on Bow down Thumbs Up
Post #350806 5th Oct 2015 8:51pm
chaybra
Australia 2006 Range Rover Vogue Td6 Zambezi Silver
Just a bit of advice for the future, all bushes that a symmetrical should be changed in pairs.
Post #350827 6th Oct 2015 4:48am
