Home > General > Mines running great.....
Page 1 of 3 123>
Just a bit fed up with reading about problems with FF's so thought I'd start a thread about how well mine is running and how much I still like it....
And I don't believe in Luck so no I haven't jinxed it...
Also my FF can't read so it'l be fine Thumbs Up
Anyone else got a behaving FF at the moment....???
Arty pic
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
-Click here for Thread-
Post #343147 18th Aug 2015 8:06pm
same here Pete, i've had mine for 2 years and no problems as well..
Post #343148 18th Aug 2015 8:07pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Only had mine for a month now but yes, it behaves great and I love every drive in it!
Post #343150 18th Aug 2015 8:08pm
pld118
Ours is great! ... only had it a month or so and it's superb. Only minor cosmetics being attended to. Not the car's fault at all.
Post #343156 18th Aug 2015 8:20pm
Zirconblue
Re: Mines running great.....
Unnecessary quote removed
I see the roads in Yorkshire are nearly as badly maintained as those in Kent. Laughing
Post #343159 18th Aug 2015 8:31pm
Zirconblue
Still working through the minor little jobs on mine, just TLC really. everything running better than it did when i got it.
Post #343160 18th Aug 2015 8:33pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Almost 1 year of ownership and been really reliable to me. Love the ride and especially love the smooth bmw engine. A few more ponnies wouldnt hurt though... Hoping to uppgrade to an 4.2 sc some day! Smile
 L322 Vogue 2003
Post #343162 18th Aug 2015 8:37pm
No, you've all misread it.... I didn't say it has been great all the time I've owned it... it just has for the last few days... well since a couple of days after Billing.... the water splash was deeper than the marshal said and three gallons poured in through the heater and soaked everything... then lit up like a xmas tree so interior out again and dehumidifier in for a few days....clean ECU's plugs etc (I have got a blind for the air intake which keeps it all out but the sodding marshal said it was half the depth it turned out to be so hadn't used it)
Anyway mine has had this lot since March 2014
Brakes
New front pads
New rear discs, pads and shoes
Suspension & steering
New front Delphi airbags and struts
New front ARB droplinks
New bottom arms
New Track control arms
New rack end
New track rod end
Johnsons rods (waste of money, you could make your own...)
New upper and lower rear hub bushes
New genuine rear shocks
Bagpipe Andy's piston ring kit
Cooling system
New radiator
New hoses
New water pump
New belt tensioners
Two new drive belts
New air con condenser
New gas...
New oil cooler thermostat
New gearbox oil cooler and manifold
New cooler pipes
Electrical
New alternator
New battery
New starter motor
New ignition switch
New throttle pedal
New throttle body
Engine
Oil and filter
2x Lambda probes
Gearbox
Oil and filter X2
New Gearbox
New Torque converter
Lights
Various bulbs and LED upgrades
New O/S rear light (thanks Craig)
Interior
New heated steering wheel
Carbon fiber wrap
New O/S/R door seal
New Android head unit
Modifications
Modified Disco D3 snorkel
New thermostat housing with 80deg stat
Twin electric fans and controller
Three piece underbody protection
Rocksliders
Under bonnet lights (well it is a Land Rover)
Concealed CB with remote switches
Voltmeter
Tracker
IID tool
Wheels and tyres
18" wheels and General Grabber AT2 275/65/18 tyres
LPG
New vaporiser
Moved and Installed new filler
Last but not least
FFRR sticker
and a few more I've probably forgotten...
It'l be sorted soon.... Rolling with laughter Rolling with laughter Rolling with laughter
Another arty shot, on a worse road....!!!
Post #343170 18th Aug 2015 8:58pm
you forgot to list your new hips Pete..... Wink ... - .- -.
Post #343171 18th Aug 2015 9:09pm
Rolling with laughter Rolling with laughter Rolling with laughter Pete
Post #343175 18th Aug 2015 9:23pm
Zirconblue
I see that 2nd pic looks like it's inside one of the Kent potholes, one of the smaller ones i think.
Post #343179 18th Aug 2015 9:59pm
sako243
Well mine's running fine today...
In the 18 months and 40k I've done:
New lift pump
6 General Grabber ATs with another 2 needed shortly
2 new batteries
New alternator
Both front airbags (Delphi's)
Dent on rear door
New wipers
2 new windscreens
Drowned Bluetooth
New front discs and pads (2 sets of pads, turns out Verdon gorge munches through them)
New rear pads and calipers
Mods:
Sump guard
Tow bar
Roof rack
PMR radio
Rear seat covers
UK custom covers boot liner
"FBH remote"
Removed side steps and mud guards Ed
Post #343180 18th Aug 2015 10:01pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Well mine was running fine last night on the way to work..... Mr. Green Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #343219 19th Aug 2015 5:15am
mzplcg
Well mine has been a breath of fresh air, especially after the last one. Only had it a few months and until yesterday it was faultless. All good things come to an end but the best it could manage was a TPMS fault. I'll take that without issue.
Mind you, like an idiot I agreed to fit a towbar to SWMBO's friends 2010 Sport last night, I mean, how hard could it be? Plug in towball except the socket was all rusty. So were all the screws holding the bumper skin on, millions of the little b*stards 'cos it's a Supercharged and has that body kit thing. 4 hours later, torch in hand I finally finished. 4 hours to plug in a towball and fit a plug in wiring loom. Only a Land Rover could do that to a bloke. Laughing
Post #343227 19th Aug 2015 8:21am
My "Trigger's Broom" also been going well for ages. Lots of odd noises and a bit of vibration here and there but all is well for MY02. .
Post #343311 19th Aug 2015 4:35pm
Page 1 of 3 123>
