![]() | Home > Maintenance & Mods (L322) > Valley Pan Leak? |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
In prepairing to do the front differential fluid I noticed a little redish drop coming from the transmission bell housing rubber inspection port. I don't know or find the official name or purpose for this rubber seal. At first I was thinking transmission before remembering the 5HP24 fluid isn't red. Pulled on the rubber seal to get a splash of coolant. IIRC this is from a leak near the back of the engine or valley pan.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
There are coolant hoses at the top back of the engine that feed off to the heater. They come from a manifold just above the bell housing so when they leak it drips down through the bell housing. The typical one to go is a short stubby one that converts from the manifold metal connection to the standard BMW plastic coolant hose clip connection. There are a couple of others but the short one is usually the culprit.
Thanks weejock, I will look their first and keep my fingers crossed. That link gave me the part number too. |
There are also gaskets where the manifold attaches to each bank of the block, they could also weep so worth a look there too. As said though, that rubber pipe is the usual suspect, it's not that expensive either.
I'm going to order one to be on the safe side but I am confused by the picture in the link thread. Part number shows the plastic tube without the tappered rubber water hose most of the time. Are these separate parts? Which section usually leaks? Thanks. |
Looking online the part number should include the plastic connector and the rubber adapter pipe which goes onto the manifold, it's the rubber pipe that splits. Certainly the parts manual shows it as all included under the one part number. There are a few different pattern part makes out there which might explain where the differences in what's included comes from. Given the small cost difference I would just go for a geniune LR part then you know it's right.
Thanks weejock, since to the best of my knowledge this part has never been changed I'm ordering one now just in case. I tried finding a BMW equivalent but it seems to be Land rover specific so around here its dealer only. A unique place that can only look up parts by VIN. If inspection is that quick I can check this morning. |
5 min job? Never that lucky. OK yes getting to it was a 5 min job. The bad news is that that hose is fine. Coolant puddle at left (facing engine bay) rear valley pan bolt. What is the consensus, new pan with sealant or reseal old pan?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8683 ![]() ![]() ![]() |
Says video is private...!!! Pete
Sorry, I fix it. Should be public now. Stupid default settings. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Pipes "look" fine, difficult to tell, do they feel spongy..?? PCV valve looks very clean, possibly been replaced already..
The pipes feel good too. I agree about the PCV. But if it does go it doesn't feel that cramped to replace later. I'm wondering if that crimped hose is a water line or just a vacuum line. If it is a water line and the pinching caused a pinhole leak that may be what I see as valley pan leak. You're right. I better be sure. |
