![]() | Home > Maintenance & Mods (L322) > Another heavy steering issue |
Pump would be my first port of call sir... Change the fluid first, if no joy, replace the pump! I would happily find a second hand pump as they don’t go wrong often so most used pumps will be good for life |
smighall Member Since: 15 Jan 2015 Location: West Sussex Posts: 68 ![]() ![]() ![]() |
Should have mentioned, also already changed the fluid a few months back. Will keep my eyes out for another pump then. Do you know if there are any differences to the pump over the various years/models? |
Also i'm assuming the same pump would have been fitted to X5's......they seem a fair bit cheaper and will probably go with a reconditioned unit if they are |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
i'd have a look at the servotronic valve wiring and make sure its ok............ ... - .- -.
Just found the pin-outs so will test the wiring for continuity, although i don't think it is that as it would then be intermittent. This seems to always be the case when i come to a stop and a slight raise in revs (only to ~1k rpm) is enough to bring the steering back to how it should be. |
to me those symptoms still point to the valve ...i gather it was fitted ok with the little replacement filter as well.. ... - .- -.
Yes, i fitted it myself and made sure the filter was properly seated etc. Then did a full flush of the fluid afterwards. |
another member here is having the same problem and thinks it could be the BCM,
I did see that but the symptoms are a bit different i think, in that his always works for a few seconds and then fails, which i agree sounds like the BCM.
Craig suggests the pump, so would pulling the pump fuse be an indication if its working or not? ... - .- -.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
GAP now offer a "Fast Lane" service for flashing the ECUs not embedded in the standard firmware (at a cost of £25 per ECU for non-Pro users). ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I'm the person having the issue with the heavy steering after startup, you can check the BCM output but putting a multimeter across pins 9 and 11 (black/white & black/red) you should have a voltage around 7-9 volts. Mine has the issue where with ignition on i get the correct voltage and unto 5-10 seconds after startup then the BCM turns all power off to the valve.
The pump is an old-fashioned belt driven mechanical pump Stan so no fuse I’m afraid. |
I'm not getting any errors on the BCM when checking for errors so i think i'm ok on the BCM front. I've ordered a reconditioned pump which will hopefully be here tomorrow so will have a tinker over the weekend and see if there's any improvement. |
