![]() | Home > Maintenance & Mods (L322) > spacers on rear |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35673 ![]() ![]() |
has anyone fitted spacers on the rear to bring out the wheel/tyre a bit more ....just curious whether its a worthwhile job.. ... - .- -.
anyone? ... - .- -.
not sure i would Mike but when you look at the rear wheels they do seem as if they need to come out a bit... ... - .- -.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Got them on the MG stan (Came with it not fitted by me) they do push the wheels out a bit and fill the arch nicely.
found these on ebay and it looks like the spacers bolt onto the existing studs and the wheels bolt onto the spacer studs....not sure on the strains on the hub this would cause..
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
People I know who fitted spacers on other green ovals have had issues with wheel bearings going, but then with off set wheels they would!
They would be better Stan as you would still support on the hub, The ones on MG are just flat plates with slotted holes, Very boy racer. However +1 for wheel bearings Mine was a blue one! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8569 ![]() ![]() ![]() |
I'm amazed that question has been on here for 3 1/2 years and nobody replied....
@Mike, i'll find something else for you to look and fettle with |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Should be fine just as long as they're good ones. In particular, note Mikey's pics: http://www.disco3.co.uk/forum/topic130597.html |
interesting, thanks.. |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 ![]() ![]() ![]() |
Proper companies like Eibach and H&R do them and it's quite popular in the Middle East.....
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
I put wheel spacers on my old td5 disco,
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Had them on my disco 3 with no issues. I will be getting some for the ff. must be Hubcentric and of good quality tho.
