![]() | Home > For Sale & Wanted > [Wanted] 3.6 tdv8 Engine wanted |
Hope its for a project & not a failure in your ownership Les! |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
its a Rangie I bought with a top end knock, that runs perfectly, but has a knock, its not injectors or Knock sensors and its hard to be firm on where the knock is from, so if someone had an engine it would just be a simple repair or we will keep digging till we find the cause or I will break it, which would be a shame given its a clean motor. |
Ahh, the one advertised of fleabay i presume? Yes saw that but was soon away on holiday etc etc |
yes its the same car, just need to fix it or break it.. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
My brother in law put in an offer but I guess you beat him to it.
Yes potentially. It's a good motor good history and clean and tidy, I knew the last owner hence took it on. |
Alan
To be honest, I doubt he would throw £7k at a car that cost £5k, or less and still has the same issue as it had when you bought it. I appreciate you've fitted several parts in an attempt to track the problem down, but nevertheless, the problem still persists. Now, it could be that it's nothing serious and at £5k, it was worth a punt, but at £7k, its starting to look less attractive.
