![]() | Home > Technical (L322) > 6HP26 Noise / Vibration |
| elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 44
The issue is a vibration accompanied by a sort of groaning sound when accelerating away from rest/low speed. It seems to be load related as if you accelerate gently it isn't noticeable but if you do it more briskly it is evident, though only briefly. With the caravan attached it is clearly evident.
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
Sounds like it could be the torque converter to me. The 2nd gear only occurrence is interesting, but thinking that could be related to the TC maps used? Would also be affected by Command Shift.
LR's Description and Operation section on the 6HP26X in the D3 here may be of interest: http://www.disco3.co.uk/gallery/albums/use...ration.pdf More docs in bbyer's gallery too: http://www.disco3.co.uk/gallery/thumbnails.php?album=5059 HTH Discovery 3 TDV6 Auto HSE Zambezi Silver
Many thanks LfW. The description & operation doc is really useful.
Are there any faults on the box? I'm no expert on it, but I would have thought a fault code (incorret gear ratio?) would be stored when such issues in the box itself occur - and possibly limp home mode. Are there any actual shifting issues?
No fault codes & no shift probs.
It is slightly odd, but these boxes are so complex, with the many different maps and modes for it to choose from mean that problems can appear quite different, and of course, the adaptive nature means no two boxes are the same! As the problem develops, multiple judders tend to occur in different gears/at certain speeds. TC lock-up behaviour varies between gears, as well as different settings (e.g. Sport allows it to lock up sooner and in lower gears).
Yes, much the same. All is now smooth again with a new TC fitted. Pick-up is better, gear changes are better. In your case, the mileage is a little lower than the point at which TC issues are normally experienced if the fluid is not changed (normally seems to be about 100-120k) but it has been known to happen sooner. It sounds like your vibration may be less severe, which would perhaps concur with the lower mileage. You might want to try a tube or two of this in the box to see if it relieves the symptoms: http://www.advancedfactors.co.uk/lubeguard...1799-p.asp Many have found it to stop the judder, though it is important to remember that it is not a permanent cure. Discovery 3 TDV6 Auto HSE Zambezi Silver
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Is it possible fora single valve to become worn or defective in the valve body which affects the operation of a particular gear? ______________________________
| All times are GMT |
