![]() | Home > Technical (L322) > FBH |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
Yes in the cold weather iit will warm engine and interior.
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
^^^ as above.
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
As well as economy i suppose it makes the engine more willing to start and reduce engine wear in really cold climates, like Poland, Finland, Siberia and Scotland. |
| ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355
Don't know about more willing to start,just makes the cab a bit more comfortable waiting for the AA to jump start you |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
When you use the remote or timer on the FBH it does not heat the engine , there is a by pass valve and it only heats the cabin but on starting the engine and it is below a certain temperature 7 or 8 degrees from memory it will continue to work to help bring the engine up to temperature quicker to help with emissions . 2008 MY Supercharged
| All times are GMT |
