Home > Maintenance & Mods (L322) > HVAC 'Aspirator' Fan
MrKev
My A/C doesn't cool, and the diagnostics are reporting 'Aspirator Fan Fault'. The A/C pressure is ok.
So I thought I'd take a look inside the HVAC control, thinking maybe the fan is stuck or something - a few internet searches led me to believe it was inside there.
Anyway, this is what I found:
Is the fan 'gone' - as in not there, someone's pinched it? I don't know what the inside is supposed to look like, but I'm reckoning there should be a fan on that large black bit.
Can anyone advise? I guess I need a new control unit... anyone got one going?
Thanks
Kev
Post #343650 21st Aug 2015 4:22pm
Can't answer your question, but can tell you my FFRR has had the aspirator fan fault since I was able to read codes @ 6 years ago, my air con works fine, though.
Usual advice on here it to take it ( your FFRR) to an A/C specialist for a check over first.... .
Post #343660 21st Aug 2015 5:44pm
MrKev
Thanks Joe, Yeah, I will do, I'm just going through the various bits and bobs I can tinker with, like the the electric seats - now fixed. I though I'd have a go at the 'fan' problem, as it was an error code, but it's useful to know that it should run as is, which means electrically it should be working for an a/c technician to diagnose the fault.
Kev
Post #343661 21st Aug 2015 5:49pm
What diagnostics are you using, some will show pressure which will give you an indication if it is just low on refrigerant or has a leak.... The two most common reasons not to be cool.... Pete
-Click here for Thread-
Post #343667 21st Aug 2015 6:16pm
MrKev
I've had the pressure tested by an a/c guy, and it's normal, but knowing there was a diagnostics fault recorded on the fan, didn't pay for full teardown of the a/c system in case it was as simple as fluff in the fan.
back to the a/c tech by the look of it.
Kev
Post #343668 21st Aug 2015 6:19pm
Oh right... for your info the aspirator fan is the small fan that sucks air in through the little grille on the front of the heater control panel, but as Joe says his works with the same fault so probably nothing to do with it, a proper code read or studying the live data should point you in the right direction.... Pete
Post #343670 21st Aug 2015 6:33pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I've got a couple of hvac control unit/switch panels from when I was fault finding my ac system, let me know if you need one.
Post #343674 21st Aug 2015 6:45pm
MrKev
@Haylands: yeah, except there's no fan in there.
@kezbo1981: I reckon, or at very least the main PCB. Can you PM me a price inc posting?
Kev
Post #343680 21st Aug 2015 7:43pm
