![]() | Home > In Car Electronics (L322) > Td6 head unit and speakers |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
HI Stevo,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
I would look for bad connections on the two speaker plugs on the top of the DSP.
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
Do I just need to remove the leather dash top |
Fortunately not, the DSP is the large black box standing vertically at the rear of the rear side compartment in the luggage space.
Thanks you will have to excuse my stupidity is the dsp behind the cover near the reverse sensor control box cheers |
Nearside rear compartment. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
You could also remove and refit the big black plug from the BM54. It feeds the dsp. Left hand side of the boot, slightly further forwards and a bit lower than the dsp. Not the one with the blue and white connectors, that's the TV module.....
Thank you all its fixed now 😀😀😀 |
What did you do ? 2011 Range Rover Vogue SE 4.4 TDV8
Un plug and re connect the box you said turn off ignition and back on hey presto all working cheers again |
