Home > Technical (L322) > Suspension fault, stuck in access height
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Had my front pads and discs changed last Saturday and afterwards the suspension was stuck in normal height with suspension fault on the dash every time the car started. Alternator gave up and was replaced. I drove it today and suspension in access height and suspension fault on dash. The switch for altering the heights does nothing and does not light up with a selected height level. LR said I needed a new battery but would have thought this would not not make suspension work.
Any ideas?
Faults getting tedious with the car at the moment
Cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #343928 23rd Aug 2015 3:50pm
miggit
You might need to reset the EAS with a tool like the IID, but have you tried going from full lock to full lock on the steering x 2, with the engine on, cos I can't remember which way your supposed to turn first Embarassed
That got rid of the EAS inactive fault on the dash when mine did it the other week Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #343940 23rd Aug 2015 4:54pm
If all the lights are out it is a hard fault, even if you fix the fault it won't come back until cleared with a diagnostic tool.
It could very possibly be caused by a dying battery, that can cause all kinds of faults, check battery voltage, should be 12.6volts with engine off and 14.4volts with it running, anything much less and the battery and/or the alternator need changing.
If you get the faults read it should tell you what fault you have.... Thumbs Up Pete
Post #343942 23rd Aug 2015 5:00pm
zarnd
They said my battery was not great and charged it and said may need a new one in the future. I would have thought that I would get transmission fault for s low battery first. Could it be the valve on the compressor?
Cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #343966 23rd Aug 2015 6:03pm
The compressor hasn't really got a valve...
It could be...
Compressor, air tank, any one of three valves, any one of four sensors, any one of four airbags, ECU, etc etc...
You need to get the codes read and then cleared and see if they return, if it was the battery they won't return....
It could be the battery because if the battery voltage is low then the replies to the ECU from the sensors in the system will be low and out of spec... so the ECU thinks there is a problem and logs a fault....... Pete
Post #343969 23rd Aug 2015 6:31pm
it would no harm to drill a small hole in the compressor filter.. ... - .- -.
Post #343970 23rd Aug 2015 6:31pm
Stan the early ones don't seem to get blocked, they are just a wide space wire mesh, nothing like as solid as the later ones... and it still won't fix his hard fault, needs a dose of diagnostic tool.... Pete
Post #343974 23rd Aug 2015 6:37pm
I'll shut up, he'll have the later one on an SC.... worth a try I suppose... Thumbs Up Pete
Post #343977 23rd Aug 2015 6:39pm
zarnd
Ok thanks for the info. Will speak to dealer tomorrow and it can go back for third trip in s week
Cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #343979 23rd Aug 2015 6:59pm
zarnd
Dealer think the compressor has burnt out but not 100% sure. They have ordered one for today and will fit and test it to see what happens. I did mention the valve on the compressor but they think mine may have burnt itself out so needs replacing.
wait and see then
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #344300 25th Aug 2015 10:34am
thanks for the update.. ... - .- -.
Post #344301 25th Aug 2015 10:41am
miggit
I'd get them to check all the air bags on the suspension, my pump self destructed trying to keep up with an air leak in the front strut, the car was around the 100k mark at the time. if yours is near that mileage then you may have a hole in spring Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #344355 25th Aug 2015 5:33pm
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Suspension
Had the same fault this morning started car supension lights went out car dropped to low position . Switch of ign left for 10 mins & disconnected batt left for 15 mins connected back up fault cleared been ok all day .
Post #344371 25th Aug 2015 7:05pm
zarnd
Compressor replaced, tested and all ok. Expensive couple of weeks with it Shocked Have also had compressor replaced before about 5 years ago from memory.
Mine has done 83k and as far as I am aware there are no leaks. It never sinks when left but will check it as car is not used every day anymore.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #344514 26th Aug 2015 1:42pm
miggit
I found the only easy way was to put it in off road mode, as the air bags are folded over themselves in normal. When I put mine in high and turned off the engine, it sounded like I had a pit of vipers under the front arches Shocked Hissing Sid eat your heart out Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #344527 26th Aug 2015 2:50pm
