Home > Maintenance & Mods (L322) > TD6 Stopped today 150kms from home |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Easy, really the cause of the trouble is in your words : "wife was driving"...
22nd Aug 2015 2:47pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Be careful if you have “brimmed it” with fuel as the tank bungs are considerably lower than the filler nozel hole sir |
22nd Aug 2015 7:08pm |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 |
okay so I checked voltage to in tank pump, 12.2v so all good, coudnt get the fuel lines to come of to check if pump was pumping so i removed fuel line from filter in engine bay, with my finger on the pipe it came out at a huge preasure, so i think both pumps are working as i would have thought the under tank pump would only pump preasure if the in tank pump was working, cleared all codes with IId tool and tried to start, only errors logged now are 00480 unknown and 03505 unknown, can someone guide me in the right direction and what else could i check physically and with the IId tool,
24th Aug 2015 9:08am |
well plugged in IId tool to check fuel preasures and electric pump preasures were perfect so cranked it over to check rail preasure and it started, so what caused it to stop?, and how can i trust it know it goes without me doing anything |
26th Aug 2015 8:33am |
