Home > Wheels & Tyres > Should I replace my 20" wheels?
Dimax
England 2012 Range Rover Autobiography TDV8 Santorini Black
We've had our 2007 L322 for about a year now. The alloys have been chipped, partly from kerbing but also possibly from rocks and stones on the track to our house. The 255/50/20 tyres now need changing so I'm wondering if I should now switch to 19" or even 18" wheels (we have 235/65/16 fitted on our P38 and have never damaged an alloy). Will higher profile tyres help protect the rims?
Post #344120 24th Aug 2015 12:03pm
mzplcg
19's will fit and there are plenty of genuine one available S/H.
18's are not going to fit over your brake calipers unless you happen to spend a King's ransom on some Compomotive ones.
I used 19's for Winter so as to minimise damage to my 20's which were a summer set. I also thought the ride quality was smoother on the 19's which was a small trade off against cornering ability. There are also more tyre choices in the 19" range including some respectable all-terrain items.
Post #344129 24th Aug 2015 12:46pm
Well the more sidewall you have the further away the wheels are from the road, I went to 18's for off roading as the 19's kept damaging the sidewalls, I also went up to 275/65/18 this gives a 7 1/2" sidewall, standard 19's have a 5" sidewall. Haven't damaged a tyre yet...
It is also noticeably more comfortable... Thumbs Up
If you go to the above tyre size you have to do a bit of trimming and raise the suspension height a bit, standard size 18's will be fine though..... Pete
-Click here for Thread-
Post #344130 24th Aug 2015 12:50pm
mzplcg
18's won't fit over the Brembos on his 2007 Pete unless he goes for those Compomotive rims that another member had. I think they were about a grand without boots though.
EDIT. This link details the Compos
http://www.fullfatrr.com/forum/topic15052....omotive+18
Post #344140 24th Aug 2015 1:36pm
There are plenty of cheap L405 20's on the market now - albeit with 255 55 20 tyres - just another option....
Post #344141 24th Aug 2015 1:44pm
Soz, posted at the same time...
Shame, it's so comfy now for my old bones...!!!! Pete
Post #344142 24th Aug 2015 1:44pm
Dimax
Thanks to all for the quick responses! I was hoping to pick up some cheap(ish) wheels that someone else was changing so looks like 19's are going to be the best option. Might fit them with winter tyres then next year pop some summer tyres on the 20's.
Post #344147 24th Aug 2015 1:54pm
Zirconblue
Sounds like a plan, you can get all season tyres too now, though they are more road orientated.
Post #344153 24th Aug 2015 2:19pm
belldarr
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
eBay Item No. 201410981656
These are cheap - worth a punt Smile
Post #344169 24th Aug 2015 4:06pm
Dimax
Thanks Belldarr - I'll keep a watch on those!
Post #344171 24th Aug 2015 4:28pm
They are buy it now for £50, watch them too long and someone else will buy them!! Pete
Post #344173 24th Aug 2015 4:41pm
belldarr wrote:
201410981656
Shocked £50 - can you find me a set of 21's for an L405 Whistle
Post #344187 24th Aug 2015 6:11pm
Dimax
Thanks again - I've bought them!
Now, if it's not opening too big a can of worms, which tyres should I get? We don't do a lot of miles but we do want to go round corners when it rains and get up our track if it snows. Grabbers have always worked well on the P38.
Post #344191 24th Aug 2015 6:40pm
mzplcg
Bear in mind those are pre-facelift alloys. You will need a new set of wheel nuts I believe.
Post #344193 24th Aug 2015 6:52pm
Zirconblue
for £50 they're still cheap even if you need new nuts.
Post #344196 24th Aug 2015 7:06pm
