![]() | Home > Wheels & Tyres > Largest tyre size to put on 20" rims? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Can we see a few more pics please as they look |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2683 ![]() ![]() |
Access height
Thank you |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
They look great. But I think you are over-cleaning your car. Let it get dirty every now and again. |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
Interesting that in 275/45 you can get a Michelin Latitude Sport 3 which get better marks all in the rankings than the standard Pirelli (which is what I have always used)
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I think the tyre rankings are going to be like anything, they're a good way of comparing like for like, even if you don't see the precise results.
Do you mean like this?
I needed to get away from the short side-walls of the standard size because their harshness was the only shortcoming of the upgrade to a CVD vehicle for my wife's injured back and because of the vulnerability on gravel and rocks. I wanted an open pattern AT tread for everyday use and preferably a carcase better able to withstand the rigours of the outback travel that I occasionally do. This new BFG size in the new pattern and compound really caught my attention - perhaps a little more extreme than necessary but hopefully no real vices. |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
What's the road noise like o these GraemeS ? |
The noise on the first outing was acceptable for my use but the ride too harsh, so dropped the pressures which fixed the harshness but the noise became quite unacceptable. The pressures are now up from 32/35 to 34/37 slightly warm for the next outing. Late the previous day they had been set to 33/36 cold. Hopefully there is a pressure at which their noise and harshness is acceptable. |
I guessed so |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Unnecessary quote removed
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i had an opportunity to buy some new genuine overfinch wheels, (I like the tiger design) and some new tyres. the wheels are the typical RRS size, so, they are I think 1/2 inch wider, with a slightly different ET size, meaning they sit outward a tiny bit more than the normal full fat size. I had wanted some fatter tyres for the FF, and the standard ones don't allow you to run along a kerb, without risking damaging the rim/paint etc. I tried a 285/50/20 on a standard FFRR rim, and it looked too fat and bulging. however, I had the new wheels to try one on, and they look better. so I t bought them, and and fitted them up. I would say, they look good, (to me) and they fill out the arch space ok. no rubbing, etc. even if I lower to access mode, and throw it round a roundabout! I guess they will throw more spray up the flanks as winter comes, but I have a nice sidewall on a 20 inch rim, and I can drag along a kerb, if I choose to. the make of these tyres, is some useless make 'sagitar' but they look like repro dunlops I think. no noises I can hear at 30- 70. incidentally. the speedo is dead on 70, when I use a iphone speedo app to check satnav speed etc. so they are of similar size overall. the tyres were so cheap and just going out of shelf life, I couldn't refuse.
MikeT Member Since: 19 May 2014 Location: Moscow Posts: 87 ![]() ![]() |
Might be a silly question. But will these 275/55/20's fit on my 20 inch wheels too? (From a 2006 4.2 SC) Also another question. Would a profile of 60 cause any issues does anybody know? Last edited by MikeT on 10th Jan 2016 9:20am. Edited 1 time in total |
Are your wheels the stock sc 20s ?
