![]() | Home > Maintenance & Mods (L322) > i got wind problems ! |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1666 ![]() ![]() ![]() |
Something has found its way into the ducting. Do you keep the scuttle plate at the base of the windscreen clear. I had small bits of debris find their way into the ducting some years ago but they eventually cleared. 405 AB exec seats Baltic and Cirrus
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
hi I have not had the car very long, but will check this. How can I gain access into the ducting to take a look? |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
+1 with above but also, if it's a buzzing sound, it could be a loose rubber seal at the base of the windscreen which resonates at speed. I've got it after a new windscreen was fitted a few weeks ago. I'm getting the dealer, who fitted the windscreen, to take a look next week. 2012 5.0L S/C
thanks for the help. I think ive sorted out the problem subject to a road test, the black plastic side windscreen trim was loose. |
