![]() | Home > In Car Electronics (L322) > Blackvue 650 dual channel installation |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
look at welshdragons dashcam install in our wiki.. |
FullFatDunc Member Since: 16 Aug 2015 Location: South Somerset Posts: 65 ![]() ![]() |
Thanks
sorry, another Q
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
I ran the wires across the roof lining on the passenger side when I installed the rear one in mine. Regards
my rear dashcam has the cable going down behind the interior 'c'? trim and down into the offside electronics cubby hole..i've left enough cable so that you can open the tailgate without stretching the cable.. ... ... - .- -.
thanks |
indeed,
thanks |
if your second camera is waterproof , have you considered mounting it next to the outside reverse camera and routing the cable via the roof trim and then down into the off side cubby.. ... - .- -.
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 256 ![]() ![]() |
I have the Blackvue 650 Dual camera and situated the rear camera centrally - see pic
that's the one Jack |
Don't remember mine going through the roof lining. I think it runs inside/behind the tailgate seal into the car by the passenger side rear speaker through left hand side of the back seat where it joins other wires under the tread plates. Then along through to the passenger side A pillar where is rises to the top of the screen where there is a void it sits behind for it to travel to the rear view mirror? I positioned my front facing camera on the passenger side of the rear view mirror. In hindsight I should have placed it drivers side as it would be easier to plug/unplug.
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
Mine goes through the roof lining.
thanks all |
