![]() | Home > Maintenance & Mods (L322) > Brakes are Humming! |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Craig, they did fit new discs too |
Ours ain't squealing nmj, they're humming |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Could be the same noise, not a squeal as such
Cheers Mark, tbh I'm quite looking fwd to having a go myself if they don't sort it at main dealer. It's just that the car is back with them for the second time to have half a dozen snags, mainly minor cosmetic sorted. Getting well versed at driving the Evoque! 4.4TDV8 is a brilliant and dare I say reasonably frugal car though! |
One of the reasons I didn't put the slip on in the first instance was that the old pads didn't have any. And relied on the sticky back plastic. Seems to have worked though.
| gotters Member Since: 15 Aug 2015 Location: London Posts: 41
hi, shame my first post is in a problem thread.
Regarding ours it's nothing to worry about. I knew that anyway as the brakes were performing as they should. Dealer has had the car back and the issue replicated for the Master Tech who concurred brakes were A1. They took the brake pads out, cleaned them, copper greased them and gave us the car back today. So far so good, noise gone |
thanks for the reassurance, no need to run back to the main dealer then (its a bit of a trek)
Tbh gotter, ours was having a few other snags dealt with and this was why I took it back. Was going to take the pads out and clean off/ regrease myself otherwise. |
just taken it out now for 20 miles around small villages and country roads and no brake noise at all, even when I tried to replicate it deliberately.
5 days since getting the car back and the brakes have been quiet ever since. A clean and a touch of grease it seems was all that was needed. |
| All times are GMT |
