Home > Technical (L322) > Smokey tdv8
Gunnerboy
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Smokey tdv8
I've just bought a tdv8 and under load eg accelerating on motorway I'm getting some black smoke is there anything I can check or do please Spencer.
Post #342832 16th Aug 2015 9:28pm
Take it back....????? Pete
Post #342838 16th Aug 2015 9:43pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Is it the 4.4 TDV8? If so it will be the turbo oil return pipe. This needs to be modified and is covered by various threads on here. Unfortunately if the car is out of warranty JLR will probably not cover the cost and it is a big job.
Post #342844 16th Aug 2015 10:00pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
His profile says 2007.
Post #342845 16th Aug 2015 10:02pm
PaulB
http://www.fullfatrr.com/forum/topic11718....lack+smoke
Post #342846 16th Aug 2015 10:04pm
If its a 3.6 then check for split hoses. But as said above! Iff you have just purchased it, why not take it back and ask for it to be rectified?
Post #342847 16th Aug 2015 10:04pm
Zirconblue
Could be something simple like a filthy/blocked air filter could be something major as already pointed out.
If you've just bought it, then it's probably work taking it back, especially if it's from a dealer.
Post #342852 16th Aug 2015 10:12pm
Gunnerboy
Checked air filter replaced it as was dirty and both hoses from inter cooler were split replaced them no more smoke onto other jobs!😟
Post #344618 26th Aug 2015 10:07pm
Post #344629 26th Aug 2015 11:09pm
That was a result then.... Thumbs Up Thumbs Up Pete
Post #344636 26th Aug 2015 11:31pm
