![]() | Home > Technical (L322) > cambridgeshire !!!!!inactive air susp, no hdc , no abs no tc |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
so do you have a range rover sport or a vogue?
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Could well be the air pump.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278 ![]() ![]() ![]() |
Check for corrosion on the pins inside the abs unit. I had all the lights come on once and the MD said "new ABS unit required" -£1200. On checking it myself I saw a little green corrosion on one pin. They hadn't even looked at it! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Where in Cambridgeshire ?
i've re-read and concur with you Alistair.. |
cakey68 Member Since: 20 Jul 2015 Location: cambridge Posts: 2 ![]() ![]() |
So update from independent he says its def abs pump, quizzed him about pressure switches, abs sensors, wiring and contacts and also battery, but he says he's checked power supply's and wiring and so forth but it's saying its a supply fault at the pump and Land Rover tech support say it's a common fallout change the pump 1500 plus labour !!!!
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1416 ![]() ![]() |
1 get yourself an IID tool - it will be money well invested and would be much less than the 400 you've outlaid already (there are other tools available for home diagnostics)
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Just a question, are we talking about the 'abs pump' or the 'abs module' faulty here? |
I reckon the ABS module needs a good look at/clean out. They collect water due to the design!
Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23 ![]() ![]() ![]() |
i had this keep comeing up on mine.
mikeb3 Member Since: 30 Aug 2015 Location: LONDON Posts: 10 ![]() ![]() ![]() |
Sorry to hear of your problems!
