![]() | Home > Technical (L322) > Trans failsafe prog |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
The metal you describe on the magnet, this is normal.
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
Hi
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8770 ![]() ![]() ![]() |
Have you tried it in manual mode?? could be the selector switch hopefully.... Pete
Yes works ok in manual changes up and down no problem but after half a mile it goes into failsafe, also tried it in auto and again goes thru the gears with no problem but then once again goes into failsafe.
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
did they also change the oil cooler for the gearbox when you got a new one? |
it was the last owner that had the box changed so not to sure. |
UPDATE on the box:-
Sorry to hear that mate.
It's a pain |
I find it really confusing that Land rover could claim the GM box as being sealed for life, especially with a mineral based fluid.
I think this is probably more to do with the quality of the rebuilt box than anything else, it is easy to do the minimum on rebuild to get it to last outside the warranty period and little more...
Just to update on the problem, I got a recon box and torque converter from Mackie Transmissions in Glasgow ( the place is huge and they have very good reviews) total cost £1840 also got new oil cooler, both pipes, o seals and pipe clamp from Dan @ Duckworth around £400 the lot.
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
Good news.remember the oil cooler is dependent on the bottom 5 rows of the radiator, so most of these older ones have had at least one new radiator. |
