![]() | Home > Technical (L322) > Heated seat. |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Maybe the fuse. I'm sure the switch and lights come on if the fuse is blown.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Had the same symptoms on my X-Type, it was the heater elements in the seat had packed up. |
Does it cool ? 2008 MY Supercharged
As said above, folks need to know if its JUST heated or heated & cooled... Different issues with different fixes! |
Sorry folks for taking so long.
Sound like the temperature sensor is fubared , on cooling its a closed loop so the temperature sensor is missed out .
Had it to the local Indi today and it's
Same motor runs the cooling and heating it's just the way the current flows across the cell affects the temperature so they must be saying it's easier to replace everything , I would have the plastic ducting changed as well if it doesn't come as part of the motor because it tends to split with time . 2008 MY Supercharged
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
Be interested to know how you get on, cost ETC as have the same issue with my passenger seat. Wife will want a warm rear come winter |
