Home > Maintenance & Mods (L322) > MY12 headlight removal |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
What's the trick to removing the headlights when the bumper appears to be in the way? |
28th Aug 2015 12:59pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
i believe you are correct Alan.. ... - .- -.
28th Aug 2015 4:04pm |
Thanks, that confirms what I encountered. Not a good design, much like the aim of the high-beam fill-in lights that I want to change because they point too low compared with the bi-xenons. |
28th Aug 2015 9:55pm |
i dont think you can adjust the main beam angle... ... - .- -.
28th Aug 2015 10:04pm |
I lowered my D4's "possum spotter" fill-in angle by fitting spacer washers under the top 2 mounts holding the bi-xenon assembly to the reflector assembly so hope to fit spacers under the bottom 2 mounts on these. With a HID kit fitted to the D4 the fill-ins became very useful. HIDs in these fill-ins momentarily provide good visibility cresting small rises when they light the road in the distance before again becoming spots on the ground not far in front.
28th Aug 2015 10:18pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
You need to remove the bumper sir |
28th Aug 2015 10:20pm |
Is there just the 1 bolt holding the bumper to the wing and how is it accessed? I wasted more time today trying to free the top of the bumper but had to put it back together again with darkness approaching. Its quite frustrating as the headlight seems to almost come out with the bumper in-situ. I'm running out of time to get decent lights working before a necessary open-country night drive next w/e, along with not really having any time to spare fiddling with the car so might have to remove the HIDs to get rid of the glaring spots just in front until I have more time.
29th Aug 2015 10:18am |
I removed the top tie-rail instead of the bumper although the left headlight was going to need more juggling to extricate it, but I only needed one to investigate anyway. I wasn't able to alter the bi-xenon mount to point the bi-xenon assembly lower, only higher. I bent the globe's locating tab forwards to make the globe point down to cause the beam to point up. A test run tonight will reveal if any adjustments to the tabs are required. |
30th Aug 2015 8:11am |
To remove the bumper you first need to remove all the fixings from the front half of the wheel arch liners, you will find a hidden bolt behind them, then remove the grille using a long flat screwdriver to put behind all four lower clips and gently twist to release the lower click fixings. Under the grille are 4 bungs and below them are four large crosshead bolts. Under the lower edge of the bumper, behind the tow eye cover are 8-12 10mm headed bolts holding the underneath of the bumper to the subframe and two more hidden higher up across from the fog lamps...
30th Aug 2015 10:04am |
Thanks Craig. I had a look around with the headlight removed and made a few mental notes. I saw that the screws into the upper bumper bracket were the ones holding the bumper firmly in place and that the bolt into the guard bracket that I thought was through the bumper is used to hold the bracket in place, not the bumper. I had already discovered the others you mentioned. The top tie-rail was quick and simple to remove but not a complete solution. Is good to know that the bumper will easily part company once the necessary screws and bolts are removed.
30th Aug 2015 11:50am |
Do you have any pics of the bent locating tabs Graham? I too have HID’s in my FB and agree they are too low! |
30th Aug 2015 12:02pm |
Here's a halogen H7 - hopefully the picture is clear enough to see the angle - probably around 30 degrees rather than 45.
30th Aug 2015 12:46pm |
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 54 |
Old thread I know, but I removed a headlight today on my 2011 Vogue without removing the bumper.
26th Dec 2019 2:58pm |
interesting , thank you ... - .- -.
26th Dec 2019 3:06pm |
