Home > Technical (L322) > The odd chirrup 4.4tdv8
Page 1 of 4 1234>
All seems to be running ok at the moment, at least It did on the 600 mile drive down to western France. (He runs into the garden and grabs the first tree)
I have been getting the odd chirrup from the car now and then when accelerating. Not something I can replicate, and it only does it occasionally. Probably half a dozen times since I have had it.....
Sounds almost like an old fashioned turbo waste gate noise ish......
Anyone else with a 4:4 get an odd noise like this?
Also I seem to have a slight flat spot in the power delivery as the secondary turbo comes in, so accelerated like a stabbed rat up to 2250rpm slight hesitation then goes again. I have heard of a similar problem on earlier cars but can't find the threads. I think a software update solved it but can't remember! Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #345141 30th Aug 2015 5:14pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
with our 3.6 TDV8 we had a warped exhaust manifold that caused a chirping on power. Not sure if thats the issue with the 4.4 but the symptoms sound similar.
NOt an easy fix, so I hope your cause is something else
Post #345145 30th Aug 2015 6:09pm
Cheers, I Hope not but would have thought it would happen more regularly if that were the case.! There is nothing that can't be fixed with a hammer😜😜
Post #345148 30th Aug 2015 6:16pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Do you think it comes from the passenger footwell because SHMBO has mentioned something similar recently. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #345180 30th Aug 2015 10:10pm
Have you had the codes read? Just incase that helps?
Post #345190 30th Aug 2015 11:17pm
pld118
Re: The odd chirrup 4.4tdv8
northernmonkeyjones wrote:
...Also I seem to have a slight flat spot in the power delivery as the secondary turbo comes in, so accelerated like a stabbed rat up to 2250rpm slight hesitation then goes again. I have heard of a similar problem on earlier cars but can't find the threads. I think a software update solved it but can't remember! Thumbs Up
Not driven ours much but on the odd 2 hour motorway run, I've noticed that from time to time on cruise control at 70mph, now and again there is the briefest sensation of the car surging forward then immediately holding itself back. Unsure if this is the 8 speed auto box self adjusting 'in flight' dependant on the road gradients; whether it's normal on the 4.4TDV8; or whether it sounds unusual (the SC didn't do it)?
Post #345223 31st Aug 2015 8:55am
Havent had them read yet Craig. It will have to wait until we get home, should really get me an Iid tool Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #345224 31st Aug 2015 9:04am
Perce
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Mine does this too occasionally. It is usually when I'm slowing for roundabouts or junctions, at about 10-20 mph. Also noticed acceleration can be flat sometimes too. Due for a service soon, so I'll mention it then, unless anyone thinks it warrants more urgent attention. Btw it's just clocked up 90k, so hopefully the turbo's not on it's last legs! Confused
Post #345248 31st Aug 2015 10:50am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
My 4.5 TDV8 is also started to make this noise. Sometimes it's very quiet, other times it's quite loud. Just been round to my local Indy and took one one the mechanics out for test run and he also heard it. They have never come across this before.
It normally happens when accelerating gently away and appears to occur at a gear change. The noise seems to coming from the front right of the car. My first thought is that it sounds similar to a turbo waste gate noise, as per previous comments.
My car is now booked into the Indy next Friday for investigations
Perce, just wondering if you got a resolution
Post #351421 9th Oct 2015 7:12pm
Post up the results, mine seems to be still only doing it occasionally, not really noticed it too much since getting back from France! There is nothing that can't be fixed with a hammer😜😜
Post #351449 9th Oct 2015 10:38pm
shinchan
Spain
I´ve the chirrup only at 1100 rpm in road, this seems a vibration of metal. The car stayed one week at LRS, unfortunately they not discover the origin.
Post #351600 10th Oct 2015 8:42pm
Buz1500
Turbo Flutter
My car is still making this noise and on a more regular basis now. I've tried searching the internet again to see if I can identify the root cause and found this link. The noise this car makes is exactly the noise my car makes.
[url]
[/url]
[/list]
Anyone has this on their car?
Post #403136 3rd Sep 2016 11:03am
TimperleyRR
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
My 3L TD6 L322 makes a more canary like high pitched chirp when you come of the gas (you can hear it if the drivers window is down). I assumed it was a normal turbo waste-gate noise. Is this not correct?
Post #403167 3rd Sep 2016 1:19pm
mine is still doing it occasionally, as you said originally it seems to be on light throttle when changing gear still. Hasn't gotten any worse though. There is nothing that can't be fixed with a hammer😜😜
Post #403172 3rd Sep 2016 2:34pm
mjdronfield
I hear mine do it when I'm backing it into my workshop, when I have to press the throttle to get up a little slope and then come off it quick. Doesn't seem to do it going forwards, but then I don't suppose you come off the throttle as quick....
Who knows....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #403184 3rd Sep 2016 4:42pm
Page 1 of 4 1234>
